Natural Type-On Expression
COW Forums : Adobe After Effects Expressions
Navarro Parker
on Jul 16, 2013 at 8:22:14 pm
The old text animator Typewriter preset is great. However, it types at a constant cadence like a dot matrix printer.
Is there a way to make a more natural type-on that emulates a human typing? Maybe something with variable micro-pauses between letters and a different variable micro-pause between words?
Dan Ebberts
Re: Natural Type-On Expression
on Jul 16, 2013 at 10:07:33 pm
Here's a Source Text expression you could play around with:
minRate = 3; // frames per character
maxRate = 6;
charCount = 0;
t = 0;
seedRandom(index,true);
while (t < time){
charCount++;
t += framesToTime(random(minRate,maxRate));
value.substr(0,charCount)
Dan
Mitch Mann
on Jul 17, 2013 at 10:41:06 am
I was thinking of some kind of wiggle expression for this. I tried your solution, Dan, and its great!
Navarro Parker
on Jul 17, 2013 at 4:09:27 pm
As usual, works great Dan!
Dovi Shraga
on Dec 20, 2013 at 2:09:09 pm
Hi Dan!
This looks just like what I'm looking for. The problem is I can't figure out where this code goes (Range Selector 1 -> Strat?). I'd be happy if you're willing to elaborate on that a little.
Dovi
Dan Ebberts
on Dec 20, 2013 at 5:23:43 pm
It's an expression for the Source Text property.
Dan
Dovi Shraga
on Dec 20, 2013 at 11:14:36 pm
I got that, but couldn't get it to work. What I did was alt+click on the stopwatch near "Source Text" and then pasted your code. When I moved the cursor to see what's happening, I saw nothing. I've also tried to disable the Typewriter effect but that didn't help either.
Dan Ebberts
on Dec 20, 2013 at 11:20:26 pm
1. Create a new text layer with your desired text.
2. Alt+click the Source Text stopwatch.
3. Paste this in:
minRate = 3;
maxRate = 6;
charCount = 0;
t = 0;
while (t < time){
charCount++;
That should do it. No Typewriter effect necessary.
Dan
Lance Clayton
on May 10, 2016 at 4:29:45 am
Thanks Dan.
However, this does seem to only work when the layer starts at the beginning of the comp. When further down the timeline all letters appear at once.
Is there some parameters that can be added to allow the expression to start at the beginning of the layer no matter how far down the timeline it is? (or will I have to precomp).
Lance
Dan Ebberts
on May 10, 2016 at 5:27:32 am
I think you just need to change this line:
t = 0;
to this:
t = inPoint;
Dan
Marcelo Cabral
on Oct 1, 2017 at 3:11:43 pm
Hi Dan
This expression works awesome as type on effect. I have a text with this expression inside a composition ("text") nested in another composition ("chat"). In this composition, I have an adjustment layer with a mark called "start". I was wondering if there is some way to make this text expression start with that mark. Thank you in advance
minRate = 1;
maxRate = 2;
charCount = 0;
t = inPoint;
while (t &lt; time){
charCount++;
Dan Ebberts
on Oct 1, 2017 at 5:05:18 pm
Something like this probably:
minRate = 1;
maxRate = 2;
C = comp("chat");
L = C.layer("Adjustment Layer 1");
t = L.marker.key("start").time - C.layer(thisComp.name).startTime;
charCount = 0;
while (t < time){
charCount++;
Dan
Marcelo Cabral
on Oct 1, 2017 at 6:26:32 pm
Hi Dan, It works perfectly. Unfortunately, I have to change some stuff. Instead of referring a name mark I have to refer to several marks in the layer without numbers or names because I have to place several text layers in the final composition all referring to the same layer marks in the outside composition. Is that possible? Thank you, I appreciate your support, Dan.
Marcelo
Dan Ebberts
on Oct 1, 2017 at 6:37:07 pm
Sorry, I'm not understanding what you're describing.
Dan
Marcelo Cabral
on Oct 1, 2017 at 6:58:40 pm
Hi Dan
This part of the expression
is referring one named mark in a layer of an external composition.
What I need is the expression works without using a "name" of the mark, just the mark. So that way I can use several text layers with the expression and they will be activated when I add more marks to the layer.
Thank you again
Dan Ebberts
on Oct 1, 2017 at 7:02:51 pm
How does the expression know which marker to use?
Dan
Marcelo Cabral
on Oct 1, 2017 at 7:09:16 pm
You completely right, Dan. I will use mark names, that will be better. Thank you again.
Marcelo
Dan Ebberts
on Oct 1, 2017 at 7:21:55 pm
If you're going to modify each expression, you could also just use the marker index, like this:
t = L.marker.key(3).time - C.layer(thisComp.name).startTime;
for example.
Dan
Marcelo Cabral
on Oct 1, 2017 at 7:45:50 pm
That will better Dan. Thank you.
Marcelo Cabral
on Oct 1, 2017 at 7:23:21 pm
Last question Dan.
In the same way, how can I set up the opacity of a layer (100/0 or on-off) using a named mark in a layer of an external composition. The same like the text but only for opacity property. Thank you.
Marcelo
Sher Safi
on Feb 17, 2018 at 10:37:13 am
Awesome expression, Dan.
Is there a way to add a Blinking cursor? that would be nice.
I also have the below expression which has the cursor but only would've been better if it had a random feeling to the typing effect.
L = text.sourceText.length;
T = time*effect("Speed")("Slider") - effect("Start At")("Slider")*effect("Speed")("Slider");
F = Math.round(time % 1);
if(F == 1 | (T0) ){Fl = "|";}else{Fl=" ";}
substr(0,T) + Fl
