Text expression to go quicker over time
COW Forums : Adobe After Effects Expressions
Caleb Sandoval
on Jul 9, 2013 at 11:12:08 pm
I am trying to change the speed from one point in time to another for the quiver text expression. I clicked the stopwatch but it brings up a yellow box. i tried changing the axis and the wiggles/second from the two places in time I wanted it to occur but it is not changing over time. It simply stays the same and changes when it arrives to the second yellow box.
Todd Kopriva
Re: Text expression to go quicker over time
on Jul 10, 2013 at 5:56:48 am
The "yellow boxes" that you're referring to are keyframes.
I strongly recommend that you start here to learn After Effects: http://adobe.ly/bjBT3P
After Effects team blog
Mitch Mann
on Jul 10, 2013 at 2:50:47 pm
Not sure I understand exactly what you're saying, but if you do the animation in a preComp, then you could simply use time remap to increase the speed over time in the main comp.
Caleb Sandoval
on Jul 10, 2013 at 4:53:11 pm
right i understood that, but usually my keyframes are usually diamonds. I thought that there was a reason why it was a box instead of a diamond this time. maybe the reason I couldn't get it to do what i needed it to
Todd Kopriva
on Jul 10, 2013 at 5:03:34 pm
See this page for the various keyframe types, including Hold keyframes.
