Move object between 3 different positions using slider control.
COW Forums : Adobe After Effects Expressions
Benjamin Taylor-Day
on Jul 4, 2013 at 7:20:13 pm
Im currently working on an animation which includes having the characters ears go up and down depending on his expressions (happy/ sad etc).
Ive currently managed to link both ears to a single slider that will move the ears up and down between 2 points: A: [2243.0,324.6] and B [2342.8,582.0], the code im using for this is:
S=thisComp.layer("Null 2").effect("Slider Control")("Slider");
A= [2243,324.6];
B= [2342.8,582];
linear(S,0,100,A,B)
However i want to insert a 3rd point so when the slider is at 50 (half way) the ear will be at [2366.9,501.6].
The code i tried was:
A= [2243,324.6];
B= [2366.9,501.6];
C= [2342.8,582];
linear(S,0,100,A,B,C)
But as i dont really understand what im saying there its not too surprising that the code didnt work.
Anyhelp at all would be very grateful. Thanks :)
Dan Ebberts
Re: Move object between 3 different positions using slider control.
on Jul 4, 2013 at 8:49:56 pm
Try it this way:
A= [2243,324.6];
B= [2366.9,501.6];
C= [2342.8,582];
if (S < 50)
linear(S,0,50,A,B)
else
linear(S,50,100,B,C)
Dan
Benjamin Taylor-Day
on Jul 4, 2013 at 9:14:40 pm
It works!!! Yaaaaaaay!
Just to get my head around this for future reference...
Your basically telling AE that when the slider is below 50 then make the scale 0-50 with points A and B at each end. When the slider is above 50 then the scale is 50-100 with points B and C at each end? When you put it that way its really simple!
Thanks so much :)
Dan Ebberts
on Jul 4, 2013 at 9:24:08 pm
I think you've got it.
Dan
Mitch Mann
on Jul 8, 2013 at 1:49:32 pm
... Or the poor man's way:
Animate it between 3 points in a preComp, then have the slider control the time remap.
Mike roberts
on Jan 28, 2015 at 11:52:59 pm
Hey! any idea how to add a fourth variable?
