Shape Trim Path matching Line Rotation?
COW Forums : Adobe After Effects Expressions
Navarro Parker
on May 29, 2013 at 9:08:50 pm
How would I get the 0-360° rotation of a line to match the 0-100% trim path operation on a circle shape?
So that the edge of the circle always lines up with the tip of the line.
Dan Ebberts
Re: Shape Trim Path matching Line Rotation?
on May 29, 2013 at 9:15:24 pm
It should just be some form of this:
tp = thisComp.layer("Shape Layer 1").content("Ellipse 1").content("Trim Paths 1").end;
linear(tp,0,100,0,360)
Depending on how you have it set up might need to add the result to (or subtract it from) some offset angle.
Dan
Navarro Parker
on May 29, 2013 at 10:14:39 pm
I see... so it's like a range mapper! Cool.
If I needed to reverse the process (I forgot I had the rotation already pickwhipped to a null), would it look like:
tp = *pickwhip rotation*
linear(tp,0,360,0,100)
Dan Ebberts
on May 29, 2013 at 10:19:48 pm
That sounds right (again, depending on how you have it set up).
Dan
