Fade In then Wiggle - Based on Layers InPoint
COW Forums : Adobe After Effects Expressions
Victor Nash
on May 20, 2013 at 9:05:38 pm
Hello All,
Im looking for an expression that fades a layer in then wiggles on based on the original value.
wiggle(1,10)
I was having difficulty adding this wiggle into the FadeIn expression
fadeInTime = .5;
fadeOutTime = .5;
Math.min(linear(time,inPoint,inPoint + fadeInTime,0,value),linear(time,outPoint - fadeOutTime,outPoint,value,0))
Dan Ebberts
Re: Fade In then Wiggle - Based on Layers InPoint
on May 20, 2013 at 9:22:41 pm
This is one way:
amp = 10;
fadeInTime = .5;
fadeOutTime = .5;
if (time < (inPoint+outPoint)/2)
a = linear(time,inPoint,inPoint+fadeInTime,0,amp)
else
a = linear(time,outPoint-fadeOutTime,outPoint,amp,0);
wiggle(1,a);
Dan
Victor Nash
on May 21, 2013 at 12:47:38 pm
Thank You Dan.
I noticed the original value I set the opacity to starts at the inpoint and outpoint but it wasn't fading in or out?
Dan Ebberts
on May 21, 2013 at 1:39:27 pm
Sorry, I misunderstood what you were after. Try it this way:
w = wiggle(1,10);
fadeInTime = .5;
fadeOutTime = .5;
linear(time,inPoint,inPoint+fadeInTime,0,w)
else
linear(time,outPoint-fadeOutTime,outPoint,w,0);
Dan
Victor Nash
on May 21, 2013 at 2:00:35 pm
Thank You Dan,
I've learned so much over the years from you. Thanks for being such an asset to this community.
