Linking rotation to comp time remap
COW Forums : Adobe After Effects Expressions
Adam Al-Hakeem
on May 10, 2013 at 5:45:23 pm
I've created a spinner game with 6 possible landing areas. As the arrow for the game spins, the landing area lights up, indicating which area the needle is over. So far I created a comp with an Arrow and a Pre-Comp with 6 frames, 1 frame for each landing area, and have been animating the light up area using time remap.
How would I write up an expression to use the Arrow's rotation to specify which time frame the Pre-Comp should be on?
Dan Ebberts
Re: Linking rotation to comp time remap
on May 10, 2013 at 6:39:57 pm
Something like this should work:
r = thisComp.layer("Arrow").transform.rotation;
f = Math.floor((r%360)/60);
if (f < 0) f += 6;
framesToTime(f)
Dan
Adam Al-Hakeem
on May 10, 2013 at 6:53:40 pm
Dan you the MAN!! One little problem, because of the way my board is setup my light up is happening 30° too late, or rather I'm 30° off.
Adam Al-Hakeem
on May 10, 2013 at 8:00:09 pm
Oh... figured it out, just added 30 to r
f = Math.floor(((r+30)%360)/60);
if (f &lt; 0) f += 6;
framesToTime(f)
