TextDocument object's "Leading" Property?
COW Forums : Adobe After Effects Expressions
Andy Kreutzberg
on May 8, 2013 at 3:05:26 pm
Hello all,
this is probably an easy scripting thing but i can't get this one to work no matter what i tried:
In a script, all parameters for characters in a text layer seem to be adjustable by the TextDocument object, except the Leading parameter. This parameter is not listed in the AE scripting guide. But why? And how can i change this value with a script?
I tried this:
textDocument2.leading = 40;
which just returns "auto" inside of after effects, no matter what value i give it, but at the same time it does not seem to fail to recognise the property because the script continues after this line.
Is there a dependancy on another value maybe or am i just using the wrong property? All other values (font size, tracking, etc) work as they should.
Dan Ebberts
Re: TextDocument object's "Leading" Property?
on May 8, 2013 at 3:11:31 pm
Leading is not accessible to scripting. The fact that your script continues without error probably just means that it has appeneded its own, non-functional leading attribute to your textDocument2 object (just a guess).
Dan
Todd Kopriva
on May 8, 2013 at 3:58:09 pm
If you want leading access in scripting, you should submit a feature request:
http://www.adobe.com/go/wish
After Effects team blog
