Getting Media Start from imported file
COW Forums : Adobe After Effects Expressions
Paul Curtis
on Apr 5, 2013 at 8:36:41 am
This is a scripting/expression question and it's really got me stumped. I have hundreds of comps to script and the base layer are MTS files. I need to generate each comp using the same timecode as the base layer.
However i've not been able to work out how to read the start time code for a footage item.
If i import the MTS and manually drag it onto a Comp that works
If i expand the project window i can see Media Start/In Point for the footage and that's correct
However i've not been able to get these values in expressions or scripting form, i've found no reference anywhere and everything i've tried has failed so far.
Help!
Many thanks
Paul
Ben Insler
Re: Getting Media Start from imported file
on Jan 21, 2015 at 6:04:14 am
did you ever figure this out? I'd love to be able to read a layer/comp start timecode. Thanks!
