Random Text Generator, in the style of an IP address
COW Forums : Adobe After Effects Expressions
Jeff Dickson
on Feb 5, 2013 at 11:29:10 pm
I'm looking for a random text generator expression, and I want to put it in the format of how an IP address would look. Example: D8-3B-10-19-F7-DC
I need to display like that with the hyphens. Any help is appreciated.
Thanks.
Jeff Dickson
Dan Ebberts
Re: Random Text Generator, in the style of an IP address
on Feb 6, 2013 at 12:30:15 am
Something like this maybe:
seedRandom(index,true);
s = "";
for (i = 0; i < 6; i++){
if (i > 0) s += "-";
str = Math.round(random(255)).toString(16).toUpperCase();
if (str.length < 2) str = "0"+str;
s += str;
s
Dan
Jeff Dickson
on Feb 6, 2013 at 12:34:31 am
That works. You're the man Dan.
In addition, how do you make it animate so it toggles between random characters?
Dan Ebberts
on Feb 6, 2013 at 1:16:02 am
If you wanted it to change 5 times per second, you could just change the first line, like this:
posterizeTime(5);
s = "";
s += str;
s
Dan
Jeff Dickson
on Feb 6, 2013 at 4:39:10 pm
Awesome. That is perfect. Thank you Dan.
