Linking effects parameter to Slider
COW Forums : Adobe After Effects Expressions
Madli Man
on Dec 28, 2012 at 5:11:21 pm
Hi again,
I have a few question, i have 8 beam effects on one layer. i would like to animate beam time after it complete one beam to another beam. Its like linking one control slider(0 to 100) to complete 8 beam one by one next.
sorry for my English.
Please help sir.
Thank you
Dan Ebberts
Re: Linking effects parameter to Slider
on Dec 28, 2012 at 6:25:34 pm
I'm not sure if this is what you're after, but you could use an expression like this for the Beam's Time parameter:
s = effect("Slider Control")("Slider");
numBeams = 8;
myIdx = 1;
range = 100/numBeams;
myStart = (myIdx-1)*range;
myEnd = myStart + range;
linear(s,myStart,myEnd,0,100)
For the second beam, you would change myIdx to 2, etc.
I hope that helps.
Dan
Madli Man
on Dec 28, 2012 at 6:47:46 pm
Hi Mr Dan,
Wah.. Thank you for solving my problem. this is the code im stuck in for years. today only resume it again. Im really appreciate it very much for code. it just i change it completion to 50%.
Thanks Dan.
madli
Madli Man
on Dec 29, 2012 at 2:00:37 pm
Hi Dan,
here is another one question. regarding indexing
this layer named "line 27" have point X Y expression, there is another layer named "null 27 that i would like reffering to target point from Index +1 or - 1 from Null 27
please help sir
Thank you.
Madliman
here is my expression for "line 27" XY :
currentNull = thisComp.layer("Null "+(thisLayer.name.substr(7,3))) // get Null name
currentNull(index+1).toComp([0,0,0]) // get point from layer above
