Resizing Text as you're typing...
COW Forums : Adobe After Effects Expressions
Ross Turiano
on Dec 23, 2012 at 2:04:46 pm
Hello, I'm still pretty new with expressions.
I want the text to fit inside a box or shape layer, without having to resize it every time I type a long phrase. Is there anyway to have the text layer automatically resize, as I'm typing it will get smaller and smaller so it fits inside a set parameter or box.
Basically, the more I type the smaller it will get, so it can fit inside a set box.
I'm not sure if this is possible, but if it is, Thanks!
Dan Ebberts
Re: Resizing Text as you're typing...
on Dec 23, 2012 at 9:58:11 pm
This Scale expression should do it. The first line is where you set the desired width.
nominalWidth = 150;
for (i = 0; i <= thisComp.width; i++){
temp = sampleImage([i,thisComp.height/2],[0.5,thisComp.height/2]);
if (temp[3] > 0) break;
left = i;
for (i = thisComp.width; i >= 0; i--){
right = i;
w = right-left;
if (w > 0)
value*(nominalWidth/w);
else
value
Dan
Armand Verhoeven
on Jan 25, 2013 at 2:13:51 pm
Your expression works Dan except AE have a lot of difficulty after the expression.
Why is that?
Dan Ebberts
on Jan 25, 2013 at 7:45:59 pm
That sampleImage() expression is a hack that chews up a lot of processing time. I would use it only as a last resort.
Dan
Michael Liu
on Feb 5, 2014 at 9:54:53 pm
Hi Dan,
I'm trying to use the expression you wrote but I can't figure out how to use it.... Do you add the expression to the scale attribute on the shape or the text?
Michael
Dan Ebberts
on Feb 5, 2014 at 10:17:05 pm
Yes, that's correct.
Dan
Michael Liu
on Feb 5, 2014 at 10:20:14 pm
It doesn't seem to be working when I'm writing the text as it's not auto wrapping the box around the text
Dan Ebberts
on Feb 5, 2014 at 11:29:45 pm
All the expression does is scale the text to keep it at a fixed width.
Dan
Michael Liu
on Feb 5, 2014 at 11:49:57 pm
I see. Thanks Dan!
Michael Liu
on Feb 5, 2014 at 11:25:11 pm
And I may be doing the wrong thing but there doesn't seem to be any relationship between the shape layer and the text.
Michael
