expression reading output of expression and misc questions regarding this
COW Forums : Adobe After Effects Expressions
Ross Klettke
on Dec 18, 2012 at 5:49:28 pm
I've always avoided using the output of one expression as an input into another expression, though I see that it is possible...
Example:
Layer 1, with an expression on its xPos: Math.sin(time)
and Layer 2, with an expression on its xPos: thisComp.layer("Layer 1").transform.xPosition
Is this sort of practice something that should be avoided or, if it is worthwhile in certain cases, are there any pitfalls to be aware of? Is there any way I can order the layers to speed up evaluation of the expressions? (Letting AE know that Layer 1 should be evaluated first and then Layer 2)
Would putting this expression on Layer 2--
thisComp.layer("Layer 1").transform.xPosition.valueAtTime(time - framesToTime(3));
-- cause any additional concerns?
Additionally, let's say that there are keyframes on Layer 1's xPos -- can Layer 3 access Layer 1's xPos value before the expression's output masked it? (the keyframe data and not the output of the expression on Layer 1's xPos)
If the above is okay, I imagine a cycle is still always a bad idea?
Example:
Layer 4, with an expression on its xPos: thisComp.layer("Layer 5").transform.xPosition * -1
and Layer 5, with an expression on its xPos: Math.sin(time * 2) * 50 + thisComp.layer("Layer 4").transform.xPosition;
--Ross
Dan Ebberts
Re: expression reading output of expression and misc questions regarding this
on Dec 18, 2012 at 10:01:36 pm
There could be a potential performance issue if you had a long chain of expressions where, for example, each expression references the same property in a previous layer. There are usually ways to avoid that.
Not directly. There is an obscure work around where Layer 1 can "publish" it's pre-expression value in negative time like this:
if (time < 0){
valueAtTime(-time);
}else{
(regular expression goes here)
Then another layer could do something like this:
thisComp.layer("Layer 1").transform.xPosition.valueAtTime(-time)
Since there is no negative time zero, you may have to add special code to handle that.
I think in best of circumstances the outcome may be unpredictable, so I'd avoid it.
Dan
Ross Klettke
on Dec 18, 2012 at 10:06:49 pm
Awesome, thanks Dan! And that "publish"-to-negative-time workaround is really interesting.
