Doubt about an expression
COW Forums : Adobe After Effects Expressions
xdominguez pukkas
on Dec 13, 2012 at 2:03:08 pm
So I posted this on the wrong forum:
I know it is simple but I am clueless when it comes to expressions:
I have a text I want to randomly change the color (using the tint effect) every two seconds for an undetermined amount of time. I have been copying keyframes, but it is no longer feasible.
What code should I use?
Thank you all!
Dan Ebberts
Re: Doubt about an expression
on Dec 13, 2012 at 6:40:33 pm
Try this on "Map White To":
period = 2;
That will give you randoms colors from the entire spectrum every two seconds.
xdominguez pukkas
on Dec 17, 2012 at 12:31:31 pm
This works!
I'd like the colors to change gradually, as if dissolving, instead of changing abruptly. What expression should I use?
© 2018 All Rights Reserved
