loopOut - How to set how many loops I want, then stop?
COW Forums : Adobe After Effects Expressions
Chase Setser
on Nov 6, 2012 at 5:41:13 am
I was wanting this text to scroll down twice (looping inside this box twice) and then stopping in the middle of the box. Is there a way to do that?
Elad Menashe
Re: loopOut - How to set how many loops I want, then stop?
on Nov 6, 2012 at 8:52:31 am
The attached code works on position property, you will need to change it in case a different property is desired.
The number of loops is set by the loops variable.
Note: the actual property change done via keyframes is considered as the first loop.
Elad
loops = 5;
FirstKeyFrameTime = thisComp.layer(index).position.key(1).time;
LastKeyFrameTime = thisComp.layer(index).position.key(numKeys).time;
if (time &lt; (loops * (LastKeyFrameTime - FirstKeyFrameTime))) {
loopOut(type = "cycle", numKeyframes = 2)
else {
position.valueAtTime(LastKeyFrameTime )
