Use Comp Name to drive position expression
COW Forums : Adobe After Effects Expressions
criis daw
on Oct 25, 2012 at 12:28:22 pm
Hi Everyone..
I have tried following some previous threads but cant get it to work so i give up.. I'll ask
I am trying to get the comp name , specifically the last number to determine to position of a layer in the comp.
ie
Screen01_frame01_flap_01
etc I would like to be able to link the y postion to the number of the flap.
Anyone ??
Dan Ebberts
Re: Use Comp Name to drive position expression
on Oct 25, 2012 at 3:25:30 pm
Something like this should work:
nameSplit = thisComp.name.split("_");
compNum = parseInt(nameSplit[nameSplit.length-1],10);
value - [0,compNum*100]
Dan
criis daw
on Oct 26, 2012 at 9:58:14 am
thanks for that..
will try it now..
back in a minute when i mess it up ..
cheers
criis daw
on Oct 29, 2012 at 4:06:15 pm
Hi
dont supose you could help me a little more could you .
I copy the expression into the postion property and I understand how the y postion is calculated.
for example comp number 17 in a comp 52 pixels high ends up with a Y value of -2530.
why is that ..?
If I understood how this number is attained I could make it so I get the number I want which is, (comp number-1)*52 . the height od the comp
thanks
criis daw
on Oct 29, 2012 at 4:19:37 pm
ahhh
its ok .
I figured out why it was not what I expected. the expression is applied to the value of the layer .. which I had already set...I works fine if I reset it to zero.
Still If you have 5 minutes to explain a little i would be very thankful.
cheers
Chris
Dan Ebberts
on Oct 29, 2012 at 10:48:21 pm
The part that converts the comp name to a number? It's all core JavaScript. The split() function to split the comp name into an array of strings, using "_" as the delimiter. The comp number will be in the last element of the array, which you access with nameSplit[nameSplit.length-1]. Then you use parseInt() to convert the string version of the number to a decimal number.
Dan
criis daw
on Oct 30, 2012 at 5:26:54 pm
thanks..
i understand i a little better.
thanks for your help with this
