Christmas tree spiral
COW Forums : Adobe After Effects Expressions
Ben Roberts
on Oct 18, 2012 at 12:09:48 am
I'm trying to edit an expression which makes a perfect 3D Xmas tree spiral which a particle generator then follows.
I know this subject has come up before and I have tried to use some tips from this thread
http://forums.creativecow.net/thread/227/12276
However nothing looks as good as my first attempt.
So the current expression begins at the top of tree and builds outwards and downwards.
I need the expression to start at the bottom and build upwards and inwards.
Original Expression:
radius=-time*30
angle=-time*300;
x=radius*Math.cos(degreesToRadians(angle));
y=radius*Math.sin(degreesToRadians(angle));
z=time*50
center=[190,400,100];
add(center,[x,y,z]);
Any help/point in the right direction would be greatly appreciated.
Dan Ebberts
Re: Christmas tree spiral
on Oct 18, 2012 at 1:30:21 am
If you're going to run it backwards, you need to pick a duration when the radius gets to zero. I've got it set 24 here:
maxTime = 24;
t = Math.min(time,maxTime);
radius = -(maxTime-t)*30
angle= -(maxTime-t)*300;
z=(maxTime-t)*50
Dan
Ben Roberts
on Oct 18, 2012 at 2:10:53 am
That's it!
I'm very grateful for your help Dan.
