Rotate with an inertial bounce? Also scale?
COW Forums : Adobe After Effects Expressions
Jim Dodson
on Oct 12, 2012 at 4:10:15 am
My new favorite expression (new to me at least) gives a nice inertial bounce on position values.
Here it is (with Dan's fix for divide by zero error):
amp = .03;
freq = 3.0;
decay = 9.0;
n = 0;
if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time){
n--;
if (n == 0){ t = 0;
}else{
t = time - key(n).time;
if (n > 0 && t < 1){
v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{value}
My question is: Is there a similar inertial bounce expression for Rotation? ALSO
For scale?
Thanks guys!!
Jim Dodson
8 Core Intel -- Mac - OSX
Dan Ebberts
Re: Rotate with an inertial bounce? Also scale?
on Oct 12, 2012 at 5:07:59 am
Did you try it with scale and rotation? It should be property agnostic.
Dan
Jim Dodson
on Oct 12, 2012 at 2:36:54 pm
** Success**
Turns out it works for scale (the amplitude was subtle so had to be increased to be noticeable). But, I got this error on orientation:
"Velocity is not supported for the orientation property."
So it had to be used on "Rotation" where it worked PERFECTLY. (I really did test this before I posted Dan, I just didn't see the bounce in the smaller icons because they were subtle -- increasing amplitude helped.)
As always Dan, thank you for your amazing talents!!
Jim Dodson
