What's wrong with this expression?
COW Forums : Adobe After Effects Expressions
JonZ MarZ
on Oct 7, 2012 at 4:13:41 am
temp = thisComp.layer("Null 11").transform.position[0];
[temp, temp]thisComp.layer("Null 11").transform.position[1]
I try to link with the pickwip the position of X and Y of a comp to a null object and there's an error poping when I link the Y coordinate or second coordinate.
The error: Expected: ;
Error occured at line 2
Property: 'position'
I'm stuck, this is an easy one usually, but for unknown reason it doesn't work. I tried to put a ; at the end of the line 2 and still doesn't work.
Dan Ebberts
Re: What's wrong with this expression?
on Oct 7, 2012 at 4:59:34 am
Why are you linking x and y separately? Doesn't this work?
thisComp.layer("Null 11").transform.position;
Dan
JonZ MarZ
on Oct 7, 2012 at 5:05:31 am
You are right, I've been picking the wrong data! I needed to pickwip the word position instead. Totally forgot that *shame*
thanks!
