randomly loop keyframes - change to color
COW Forums : Adobe After Effects Expressions
wouter sel
on Sep 6, 2012 at 8:43:29 am
Hi, i want to randomly loop keyframes using an expression.
I've made 4 hold keyframes in the Change to Color effect of a layer;
so that's 4 specific colors (not random) i want to cycle in a random order over time.
I also want to be able to edit the speed of the color flickering.
Pre-comping the layer for time-remapping is not really an option,
since i have 100+ layers in the comp, and they all should flicker randomly between those 4 colors.
Dan Ebberts
Re: randomly loop keyframes - change to color
on Sep 6, 2012 at 1:20:43 pm
Something like this should pick a random keyframe value every half second:
period = .5;
seed = Math.floor((time-inPoint)/period);
seedRandom(seed,true);
if (numKeys > 0){
n = Math.floor(random(numKeys))+1;
key(n).value;
}else
value
Dan
wouter sel
on Sep 6, 2012 at 1:31:11 pm
Thanks for the reply Dan, I'll give it a try!
meanwhile I've found this after some digging, and it works great:
posterizeTime(12); // value is in fps
r = Math.ceil(random(0,numKeys));
valueAtTime(key(r).time)
