Clock/timer that updates every 2 seconds
COW Forums : Adobe After Effects Expressions
Matthew Reilly
on Aug 30, 2012 at 1:57:41 pm
Hi there Im not that great with expressions…. and I need clock/timer that counts up in clock format but only updates every 2 seconds
e.g.
20 being hours / 56 minutes / 18 seconds
20:56:18
20:56:20
20:56:22
20:56:24
Also the time needs to be able to be set.
can any one help or at least point me in the right direction?
Thanks Matu
Dan Ebberts
Re: Clock/timer that updates every 2 seconds
on Aug 30, 2012 at 2:51:50 pm
Probably something close to this:
startHr = 20;
startMin = 56;
startSec = 18;
function pad(n){
str = "" + n;
if (str.length < 2) str = "0" + str;
return str;
tStart = startHr*3600 + startMin*60 + startSec;
delta = Math.floor((time - inPoint)/2)*2;
t = tStart + delta;
h = Math.floor(t/3600)%24;
m = Math.floor((t%3600)/60)
s = t%60
"" + pad(h) + ":" + pad(m) + ":" + pad(s)
Dan
Matthew Reilly
on Aug 30, 2012 at 3:18:23 pm
Cool that works but just one more thing is it possible to get it to update every frame? so it is more like a time stamp to that frame
thanks for the help
Mat
Dan Ebberts
on Aug 30, 2012 at 3:31:08 pm
I'm confused. Does that mean you want it to update more often than every two seconds? Even if it updates every second, it won't change every frame. Or are you asking for a different time format that includes frames?
Dan
Matthew Reilly
on Aug 30, 2012 at 3:33:05 pm
sorry for the confusion that is my fault
You did what I asked for but then I realised that I would need the time to jump by 2 seconds every for frame so it is more of a timestamp to every frame.
Mat
Dan Ebberts
on Aug 30, 2012 at 3:48:31 pm
Ah, OK -- like this then:
startHr = 20;
startMin = 56;
startSec = 18;
function pad(n){
str = "" + n;
return str;
delta = Math.floor(timeToFrames(time - inPoint))*2;
t = tStart + delta;
s = t%60
Dan
Matthew Reilly
on Aug 30, 2012 at 3:53:10 pm
Ok that is now counting up in 2's for every frame but it seems to have lost the time formatting... is there something Im missing?
Mat
Dan Ebberts
on Aug 30, 2012 at 3:58:27 pm
30 frames in, I'm getting "20:57:18". What are you getting?
Dan
Matthew Reilly
on Aug 30, 2012 at 4:01:10 pm
Im getting just 720
edit "hold on.... my bad I missed some of the last bit of the code"
Dan Ebberts
on Aug 30, 2012 at 4:08:38 pm
Are you sure you pasted in the whole expression? I just tried it (copied and pasted from my post) and it works for me.
Dan
Matthew Reilly
on Aug 30, 2012 at 4:10:58 pm
Yeah I updated my last post... I missed the last part of the expression because I copied it out of the gmail reply which cuts of the post.... DOH but it is working now like a dream thanks Dan ;)
very helpful
