quick wiggle issue
COW Forums : Adobe After Effects Expressions
Tom Durham
quick wiggle issue
on Aug 8, 2012 at 9:21:13 am
Greetings Folks,
I've got a simple "follow the leader" expression linked to sliders on a control layer.
By the end of the expression it figures out what its position needs to be, which is great. But in addition to following the layer above it, I also want it to wiggle. I have no idea where to go from there.
THANKS MUCH!!!!
-Tom
a=thisComp.layer("SQUARES - right hand").effect("wiggle a")("Slider");
b=thisComp.layer("SQUARES - right hand").effect("wiggle b")("Slider");
w=wiggle(a,b);
delay = thisComp.layer("SQUARES - right hand").effect("follow delay")("Slider");
d = delay*thisComp.frameDuration;
thisComp.layer(index - 1).position.valueAtTime(time - d)
YOU can help save TimeSpace. Join the Chronos Protectorate!
http://www.95ers.com
http://www.SpaceAceMedia.com
Dan Ebberts
Re: quick wiggle issue
on Aug 8, 2012 at 1:22:40 pm
I haven't tested this, but try changing the third line to this:
w=wiggle(a,b)-value;
and the last line to this:
thisComp.layer(index - 1).position.valueAtTime(time - d) + w
Dan
Tom Durham
on Aug 8, 2012 at 8:36:52 pm
PErfect!!!! thanks so much.
