Can a script write an expression?
COW Forums : Adobe After Effects Expressions
Jake Revill
on Aug 7, 2012 at 6:26:31 pm
Hello all, I have searched high and low for an answer for what seems to be a simple question:
Can you write a script that applies an expression to a particular attribute for you?
I have an expression I would like to apply to a position attribute:
value + [Math.sin(time),Math.cos(time),0];
I can do this easy inside after effects by alt clicking the stop watch, but i want to be able to run a script that does this for me.
Can this be done and if so how?
Any help would be greatly appreciated!
Dan Ebberts
Re: Can a script write an expression?
on Aug 7, 2012 at 7:12:27 pm
Assuming it's the first layer and it's selected, this should work:
var myLayer = app.project.activeItem.layer(1);
myLayer.property("Position").expression = "value + [Math.sin(time),Math.cos(time),0];";
Dab
Jake Revill
on Aug 7, 2012 at 7:14:12 pm
Thank you so much, it was the simple .expression I was looking for all along.
Cheers Dab, or did you mean Dan? :)
Dan Ebberts
on Aug 7, 2012 at 7:17:17 pm
I do that all the time--probably because the b and n keys are right next to each other.
Dan
