disable x, z orientation, keeping y?
COW Forums : Adobe After Effects Expressions
Laco Gaal
on Jul 18, 2012 at 8:48:38 am
I have tracked a camera in AE, got a camera with keyframed position, and keyframed orientation values.
I would like to disable to position movement (deleted all the keyframes), and all the orientation values, except the Y value!
(I would like to rotate the camera only one axis)
Is this possible?
Thank you
Dan Fredley
Re: disable x, z orientation, keeping y?
on Jul 19, 2012 at 4:37:47 am
You could do it a couple of ways, but one way would be to set this expression for both position and orientation:
x = 0; // change this to your desired x value
y = value[1]; // DO NOT CHANGE
z = 0; // change this to your desired z value
[x,y,z]
