cloning the movement of a parented 3D camera
COW Forums : Adobe After Effects Expressions
Barend Onneweer
on Jun 20, 2012 at 10:03:39 pm
I'm trying to link a camera in a separate comp to the main camera. The main camera is parented to a null, but I'd like to avoid doing the same for the clone camera. So for the position I'm using:
L = comp("compB").layer("Rigged Camera"); L.to_world([0,0,0]);
But for orientation/rotation it's a bit more complicated. I found Dan's example of:
u = L.toWorldVec([1,0]);
radiansToDegrees(Math.atan2(u[1],u[0]))
But I can't seem to get it to work properly... I probably need to separate the 3 directions in the array but the syntax is beyond me... As is the math...
So thanks again for any pointers :-).
Raamw3rk - independent colourist and visual effects artist
Barend Onneweer
Re: cloning the movement of a parented 3D camera
on Jun 20, 2012 at 10:23:29 pm
Hah... the third attempt at Googling brought the solution:
http://aenhancers.com/viewtopic.php?f=9&t=653&start=30
(also thanks to Dan!).
