Inverse values using expressions
COW Forums : Adobe After Effects Expressions
Patrick Quigley
on Jun 5, 2012 at 11:28:00 pm
Hi, new to CCOW (and expressions).
quick question:
I have an output value which I need to alter the source blend of an effect through an expression. Problem is that the smaller value of the source blend the greater the effect. 100 = off, 1 = full strength. I need the opposite outcome. The output is from Soundkey, so as the the range peaks I need the effect to be at it's strongest.
I hope that makes sense and someone can help
Many Thanks!!
m=thisComp.layer("soundkey").effect("Sound Keys")("Output 1")
Patrick Quigley
Re: Inverse values using expressions
on Jun 5, 2012 at 11:40:46 pm
...yeah I figured it out...feel slightly embarrassed :D
amazing what a 'minus' can do
© 2018 All Rights Reserved
