minus sign in external data = bug ?
COW Forums : Adobe After Effects Expressions
Nicolas Elsig
on Jun 1, 2012 at 1:48:38 pm
hello I'm loading external data from a text file ... everything is fine with the eval expression taking the data based on the name of the comp
here's the external data
Sion = ["+23°C","+36°C"];
Monthey = ["+1°C","+25°C"];
St-Gingolph = ["-6°C","+21°C"];
the last line St-Gingolf is making AE to say : warning Class "global" has no property or method named "St" Expression disabled
can somebody help please ?
myPath = "/Expressions/";
myPath += "externalData.txt";
$.evalFile (myPath);
eval(thisComp.name)[0];
Dan Ebberts
Re: minus sign in external data = bug ?
on Jun 1, 2012 at 2:58:51 pm
St-Gingolph is not a valid variable name in JavaScript. St_Gingolph would work.
Dan
Nicolas Elsig
on Jun 2, 2012 at 6:52:29 am
Thank you Dan for the precision. I will work with an underscore.
