luma to drive animation of multiple comps
COW Forums : Adobe After Effects Expressions
andy acourt
on May 29, 2012 at 12:19:45 pm
Hi, I trying to animate the scale of an array of comps from a background fractal map. So for instance if the luma of a the section of fractal behind a particular comp was 100% white that comp's scale would be 100%
Thanks in advance
Wim Bruyninckx
Re: luma to drive animation of multiple comps
on May 29, 2012 at 1:07:15 pm
not sure of this will help you but;
I would suggest to use the nifty expression sampleImage() in the scale property layer
of each comp you want to scale in your array :
the expression would be:
100*[thisComp.layer("GreyscaleMap").sampleImage(position)[0],thisComp.layer("GreyscaleMap").sampleImage(position)[0]]
position = the position of your current comp you want to scale
where GreyscaleMap = your fractal map...
multiply it by 100, because sampleimage returns a value between 0 and 1.
Kind Regards
Wim
graphic designer / illustrator
http://www.flickr.com/photos/wixwix/
http://www.wimbr.be
Dan Ebberts
on May 29, 2012 at 1:21:31 pm
It would probably be like this:
target = thisComp.layer("background");
rgba = target.sampleImage(target.fromComp(toComp(anchorPoint)), [.5,.5], true, time);
luma = rgbToHsl(rgba)[2];
[luma,luma]*100
Note that this is set up for a 1-pixel sample--you might want a larger area, depending on your setup.
Dan
andy acourt
on May 29, 2012 at 4:24:03 pm
thanks for this, unfortunately I cant get it to work and I'm sure its me.
the fractal is on layer 1 and called "GreyscaleMap"
the comp I want to scale is on layer 2 and called "comp"
I've applied the script to scale property of the "comp" layer
and thats where my understanding falls apart - any more help would be greatly appreciated.
thanks
Wim Bruyninckx
on May 29, 2012 at 6:21:44 pm
make sure you precomposed the fractal layer, otherwise it won't work
andy acourt
on May 29, 2012 at 9:11:34 pm
thanks for both of your help, especially Dan, it worked in the end. The problem was the fractal map had 3D turned on. As soon as I turned it off the script worked.
