Link parameter to time?
COW Forums : Adobe After Effects Expressions
Noel Powell
on May 19, 2012 at 6:11:50 am
Hi, I'm wondering if there's an expression to continuously change a parameter without using keyframes and without the parameter ever repeating the same value (so the wiggle expression is out). The parameter I want to change is the evolution of a Fractal Noise effect. It needs to steadily increase in a linear fashion (not randomly) - so I guess eventually, it would have to loop, since it only goes up to 90 360-degree revolutions or something. Is there maybe a way to link the evolution to the comp's time code value?
Thank you!
Dan Ebberts
Re: Link parameter to time?
on May 19, 2012 at 6:44:21 am
Something like this should work:
rate = 50; // degrees per second
rate*time
Dan
Noel Powell
on May 19, 2012 at 1:41:25 pm
That is perfect. Thanks so much.
