expression counting from 0% to 100% and start at 0 again.
COW Forums : Adobe After Effects Expressions
Sarah Schela
on May 17, 2012 at 3:50:03 pm
Hello,
I looked through the forum for an answer to this question, but haven't found one.
So as it is written in the title I am looking for an expression which counts from 0% to 100% and starts at 0% all over to 100% again in a loop.
I just found this expression saying that the counter runs from 0% to 100% but then decreases to 0% and starts counting upwards to 100% again.
freq = 1;
50*(1 - Math.cos(freq*time*Math.PI*2))
so I believe there must be some kind of "if" like "if the number reaches 100 start at 0 again" or something. but I have not much experience so I hope for some advices!
Kevin Camp
Re: expression counting from 0% to 100% and start at 0 again.
on May 17, 2012 at 4:02:40 pm
this should do it. just set the freq value to the loop point.
freq = 1; // value in seconds
timeToFrames(time % freq) + "%"
i also added the % sign in there... if you don' need that delete the + "%".
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Kevin Camp
on May 17, 2012 at 4:09:18 pm
i'm sorry, that really doesn't work quite right... i should test before i post.
this should do it though:
freq = 2; // value in seconds
Math.round(linear(time % freq, 0, freq, 0, 100)) + "%"
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Dan Ebberts
on May 17, 2012 at 4:27:22 pm
If you're just looking for something that counts from 0 to 100 and then starts over, this might work for you:
rate = 30;
Math.round((time-inPoint)*rate%101)
Set the rate to whatever makes sense for your application.
Dan
Sarah Schela
on Jun 21, 2012 at 1:51:53 pm
Thanks so much! really great!
