non circular spiral
COW Forums : Adobe After Effects Expressions
Chifei Soong
non circular spiral
on May 17, 2012 at 7:20:46 am
Hi CCgurus :) how to create a non-circular spiral position (constant speed) using expressions?
My current clumsy solution is:
loop the null-A around a predefined path(pasted mask on position) using loopOut. and then parent that object to another shrinking/expanding null-B.
and finally attach a writeOn/Particular fx to nullA
is it possible to achieve this in a more elegant way by using expression without for-loop where the shape of spiral could be defined by rotation angle?
thanks in advance :)
Dan Ebberts
Re: non circular spiral
on May 17, 2012 at 1:12:58 pm
I'm not sure what you mean by non-circular spiral. Does something like this work?
t = Math.max(time-inPoint,0);
r = 50*t;
f = 1;
center = [thisComp.width,thisComp.height]/2;
a = f*t*Math.PI*2;
x = Math.cos(angle);
y = Math.sin(angle);
center + [x,y]*r;
Dan
Chifei Soong
on May 17, 2012 at 1:48:15 pm
thanks Dan,
below is an expression of a shrinking circular spiral -
what i wanted to achieve is a square (or triangle) kind of spiral movement. which looks like this :)
will best if the shape of the spiral can be controlled by an angle value Or numOfSides
thank you for your time :)
//circular spiral
c=C.layer.position; //center
r=linear(time,inPoint,inpoint+3,300,0); //radius
x=r*Math.sin(time*20);
y=r*Math.cos(time*20);
c+[x,y]
Jorge Estrada
on May 30, 2013 at 3:00:30 am
how can i make it into triangular?
Xavier Gomez
on May 30, 2013 at 2:34:07 pm
This works for any polygone. It can be simplified though if you need a regular shape, and it is probably easier to animate the "angle" and the "radius" with aditionnal sliders than to use functions (caps are to see them for afar...)
///////////////////////////////// TWEAKS ///////////////////////////////////////
function ANGLE(t){ // returns an angle in degrees...
return t * 60;}
function RADIUS(angle){ // angle is in radians ...
return angle * 10;}
center = [thisComp.width*0.5, thisComp.height*0.5];
angleList = [0,30, 120,150, 240,270] // degrees, in increasing order, from 0 (included) to 360 (excluded)
last = angleList.length-1;
a=ANGLE(time); // use a function as above, or a slider to animate the angle (same for the radius)
n=Math.floor(a/360);
b=a-n*360;
if (b&lt;=angleList[0]){ // &lt; === "less or equal"
a1 = (n-1) * 360 +angleList[last]; a2 = n*360+angleList[0];
else if (angleList[last]&lt;=b){
a1 = n * 360 + angleList[last]; a2 = (n+1)*360+angleList[0];
else{
idx=0;
while (b>angleList[idx+1]){idx++;};
a1 = n * 360 + angleList[idx++]; a2 = n*360+angleList[idx];
a = degreesToRadians(a);
a1 = degreesToRadians(a1);
a2 = degreesToRadians(a2);
P = RADIUS(a1) * [Math.cos(a1), Math.sin(a1)];
Q = RADIUS(a2) * [Math.cos(a2), Math.sin(a2)];
center + linear(a, a1, a2, P,Q)
