refreshing compositions and layers
COW Forums : Adobe After Effects Expressions
Eli Heli
on May 11, 2012 at 2:29:17 pm
Hi there,
i tried to duplicate a composition, which contains an effect.
after duplicating it, i created a new composition and put both compositions into it.
my problem now is, that both compositions (the original and the duplicate) just show a black frame, they don't seem to be active anymore. i have to double-click on both of them, so that they are getting refreshed.
what i've found out is, that if i disable the effects everything works fine.
so is there a way to refresh the effect? disable and enable doesnt seem to work.
this sounds like a really simple task, but i wasn't able to find a solution for it yet.
thank you and bye!
