custom particle orient toward center of the comp
COW Forums : Adobe After Effects Expressions
Sarah Schela
on May 10, 2012 at 3:43:38 pm
Hello there,
I am looking for a way to orient the custom particle generated with particular towards the center of the 3D comp. (I wanna try a kind of ring where all elements face the center point).
I'm using an expression for "rotate y".
I tried to use the expression "lookAt" (lookAt(position,thisComp.layer("Null Camera 6"))-> Null Camera 6 is the center position), but unfortunately it doesn't work.
It must be possible somehow! Any help appreciated.
Sarah Schela
Re: custom particle orient toward center of the comp
on May 10, 2012 at 3:53:42 pm
lookAt(position,thisComp.layer("Null Camera 6").position)[1]
works better. but just on "two sides" of the circle.
