Explain this function?
COW Forums : Adobe After Effects Expressions
Christopher Abbas
on May 4, 2012 at 10:36:58 pm
Hi guys,
This is my first post! I'm studying a book by Marcus Geduld named After Effects Expressions and ran into a function that confuses me. I'm just wondering if someone is able to help me break it down to the basics. The purpose is to randomly pick a different value for rotation on every frame.
I'd appreciate any help, cheers.
function pickRandomNumber(arrayOfNumbers) // Define the function and the input.
var randomNumber = random(arrayOfNumbers.length); // Randomly generate numbers, but within the range (length) of arrayOfNumbers?
var myIndex = Math.floor(randomNumber); // Take the numbers generated from randomNumber and round them down?
return arrayOfNumbers[myIndex]; // I don't understand what is happening here. Are we determining how this part of the function works or will accept myArray?
myArray = [10,20,30,40,50,60]; // Got it, this is an array of numbers.
pickRandomNumber(myArray); // Call the pickRandomNumber function and use myArray as the input?
Dan Ebberts
Re: Explain this function?
on May 4, 2012 at 11:31:07 pm
The first line of the function generates a random number between 0 and 5.99999... (the upper limit is slightly less than the length of the array).
The second line rounds the random number down so you get a random integer in the range of 0 to 5, inclusive (the legal range of indexes into the array).
Christopher Abbas
on May 7, 2012 at 6:13:03 pm
Hi Dan,
Thanks for the response and explanation, I really appreciate it!
© 2018 All Rights Reserved
