3d Layers Pop up when a numerical value is getting close
COW Forums : Adobe After Effects Expressions
Jeff Bobbington
on May 2, 2012 at 2:29:21 pm
Hey all,
I'm sure this will be an easy one for some of you..
I'm creating a scrolling gallery where the images rise closer to the camera, when it passes.
The camera flies to positions designated by a #NUMBER value (in the Sure Target 2 script). I want to control the image rise based on this #NUMBER value.
The images need to pop up when the camera is approaching from the last image. Kind of like a menu select screen or scrolling album gallery.
So, when the camera flies to image 4, #NUMBER is changing from 3.0 to 4.0.
I want the image to begin rising (by 900 on its Z Anchor Point) from #NUMBER=3, be fully raised by #NUMBER=4 and then return to zero by #NUMBER=5.
This will obviously need applying to the hundreds of image layers im working with. Each one represented by a different #NUMBER.
I'm not sure how to tell the layer that it needs to go from 0-900 in the space of #NUMBER=3 to #NUMBER=4, and then back down in the space of #NUMBER=4 to #NUMBER=5.
Any ideas?
Dan Ebberts
Re: 3d Layers Pop up when a numerical value is getting close
on May 2, 2012 at 5:34:29 pm
I have no idea how to get access to the #NUMBER value, but once you have that, the expression should look like this:
num = #NUMBER; // I don't know what this is
if (num < 4)
z = ease (num,3,4,0,900)
else
z = ease(num,4,5,900,0);
value + [0,0,z]
Dan
Jeff Bobbington
on May 3, 2012 at 3:45:31 pm
Hi Dan,
Firstly, many thanks for the reply, you're an inspiration to many AE'ers!
Keep up the great work in helping the community!
The expression worked great, so I replaced any values which were unique to that layers number, to a slider number to match the #NUMBER of that layer.
The result was as follows! So I could just paste it on each layer.
Would you happen to know where I can learn more about what expressions to use and when, most of the time I know what I need to do, just not the language!
num = thisComp.layer("Sure Target").effect("Sure Target")(18);
if (num &lt; effect("Slider Control")(1))
z = ease (num,effect("Slider Control")(1)-1,effect("Slider Control")(1),0,900)
else
z = ease(num,effect("Slider Control")(1),effect("Slider Control")(1)+1,900,0);
value + [0,0,z]
Darby Edelen
on May 5, 2012 at 5:45:26 am
[Jeff Bobbington] "The expression worked great, so I replaced any values which were unique to that layers number, to a slider number to match the #NUMBER of that layer."
If the #NUMBER of the layer has a predictable relationship to the index of that layer then you could automate this in the expression.
index returns the index of the layer as seen in the timeline.
Darby Edelen
