Editing Text
COW Forums : Adobe After Effects Expressions
Yasush Azush
Editing Text
on Apr 13, 2012 at 2:59:59 pm
Hi Guys,
I was just wondering if it is possible to edit a text layer while I'm outside the actual comp which contains the text layer.
Dan Fredley
Re: Editing Text
on May 24, 2012 at 3:22:57 pm
If it's inside a precomp you can go to view>new viewer and it will lock the main comp viewer window so you can open the precomp and see the changes in both comps as you edit the text. That's about it though.
Dan Fredley
© 2018 All Rights Reserved
