clamping a slider value but having two different effects for 'above' and 'below' the limits
COW Forums : Adobe After Effects Expressions
jim lefevre
on Mar 14, 2012 at 11:57:01 am
I've not really used the clamp expression much so I may be starting on the wrong footing here but...
I have a slider (CLOUD_position_DRIVER) with values 0 to 100
when CLOUD_position_DRIVER < 0 I want CLOUD_position value = 0
and
when CLOUD_position_DRIVER > 100 I want CLOUD_position value = 100
but obviously in between those two ranges (CLOUD_position_DRIVER between 0 and 100) I want the position to be a variable value.
So basically I want to clamp it so that below a certain value it reads a fixed first state, between the value a variable state and after a certain value a third fixed state (different to the first fixed state).
I've tried...
if (effect("CLOUD_position_DRIVER")("Slider")<0) {0} else {value};
if (effect("CLOUD_position_DRIVER")("Slider")>100) {100} else {value};
but it's not working, or rather the second statement is working but not the first! Which is why I was thinking that the clamp thing might be something I need? Maybe not?!
many thanks in advance
jim
http://www.jimlefevre.com
Dan Ebberts
Re: clamping a slider value but having two different effects for 'above' and 'below' the limits
on Mar 14, 2012 at 5:20:25 pm
clamp() should work nicely, like this:
clamp(value,0,100)
Your expression would have worked if you had use else if(), like this:
if (value < 0){
0
}else if (value > 100){
100
}else{
value
Dan
jim lefevre
on Mar 19, 2012 at 9:26:37 am
Ahhh... a stacked if - else -if
That's the puppy.
In actual fact I managed a bit of a work around in the meantime which is far less elegant which pre-works-out a value before it heads into the main if statement
if (SLIDER_value < 0) then {VALUE_onoff = 0} else {VALUE_onoff = 100);
VALUE_var = SLIDER_value;
if (SLIDER_value > 0) then {VALUE_var} else {VALUE_onoff)
but I'll go back in and try that other suggestion for the sakes of personal education.
Thank you thank you thank you
x
jim
