Changing objects color over duplication
COW Forums : Adobe After Effects Expressions
Gus Favassa
on Feb 22, 2012 at 10:10:56 am
Hello guys, this is my first post here!
I've searched the whole internet and couldnt find any topics regarding the use of the expression "effect("Hue/Saturation")(value)".
I want to change this object layer color by inserting a random value through the colorize hue property each time a duplicate it, but it doesnt seem to work. When I alt click it, AE gives me this random value (7) in my case, and it doesnt work when I change it. Any ideas?
Thanks in advance!
color = value(360, 0);
effect("Hue/Saturation")(color)
Kevin Camp
Re: Changing objects color over duplication
on Feb 22, 2012 at 3:39:11 pm
for what i think you are doing, i think all you need is to put a value in the expression field. you don't need to specify the effect property of the property that you are applying it to... that part is implied.
ie, you could simply enter 57 as the expression and the result would be the value for that property would be 57.
since you just want a random value, try just random(0,360); you should need anything else.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Gus Favassa
on Feb 22, 2012 at 5:36:42 pm
Perfect!
It works now. I didn't know it was that simple!
Thank you so much!
Dan Ebberts
on Feb 22, 2012 at 6:25:59 pm
If you don't want it to change every frame, you'd also want to set the random seed:
seedRandom(index,true);
random(0,360)
Dan
