Counting Expresson not working.
COW Forums : Adobe After Effects Expressions
John Cuevas
on Feb 15, 2012 at 7:58:47 pm
I add this expression to my Source text and I keep recieving an "invalid numeric result(divide by zero?) error.
If I change the "myNum = time" no error, it displays time + percent. Also if I just link to the slider, no error, my number is displayed.
It's not that I can't just put a percent sign behind the counter, I want to know why this isn't working
myNum = effect("Slider Control")("Slider");
myNum + "%"
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dan Ebberts
Re: Counting Expresson not working.
on Feb 15, 2012 at 8:33:49 pm
Sometimes the expression engine doesn't automatically convert expression control objects to values and you have to explicitly tell it to do so, like this:
myNum = effect("Slider Control")("Slider").value;
myNum + "%"
This is another way to fix it:
"" + myNum + "%"
Apparently forcing the string conversion (with the "") also causes the value to be retrieved.
Dan
John Cuevas
on Feb 15, 2012 at 8:36:21 pm
Thank you Dan, that was driving me nuts. Good thing to remember for the future.
Thinkck.com
