text strings
COW Forums : Adobe After Effects Expressions
Tom Durham
text strings
on Feb 11, 2012 at 7:41:56 pm
I'm crashing on a project this weekend... hopefully someone will see this! :)
Linking expressions using layer and comp names.
This is easy:
n1 = thisComp.name.split(" ")[0];
comp("MASTER PERIODIC TABLE").layer("MASTER CONTROL").effect(n1)("Color")
My layer name is "11 Na Sodium". (Doing a fancy science anim.)
But what if I need my effect in MASTER PERIODIC TABLE to be "11 Na COLOR."
How do I string together text snippets and add the world COLOR?
n2 = thisComp.name.split(" ")[1];
comp("MASTER PERIODIC TABLE").layer("MASTER CONTROL").effect(???????????????????????????)("Color")
Thanks MUCH for any help.
-Tom
YOU can help save TimeSpace. Join the Chronos Protectorate!
http://www.95ers.com
http://www.SpaceAceMedia.com
Tom Durham
Re: text strings
on Feb 11, 2012 at 7:53:03 pm
Thanks to one of Dan's earlier posts I found the answer. THANKS DAN!
comp("MASTER PERIODIC TABLE").layer("MASTER CONTROL").effect(n1 + " " + n2 + " ind COLOR")("Color")
