Controlling the start time of a layer
COW Forums : Adobe After Effects Expressions
ibrahim cengiz
on Feb 8, 2012 at 12:22:23 pm
Hi
My comp is based on a slide show. Slides durations are controlled by a slider.
I am trying to achieve an audio loop cycle with expressions.
I have an audio of 2 seconds long. I want to replay audio but i want to control the distance between loops (i am using it as a transition sound between slides)
1- Is it possible the looping sound in one layer?
2- I can dublicate the layer by the number of slides. Is there a way to control the beginning point of a layer?
Thanks in advance
Dan Ebberts
Re: Controlling the start time of a layer
on Feb 8, 2012 at 5:27:53 pm
If you need to move layers around in time, it sounds like a job for a script, not an expression. With a script you could do the whole thing--duplicate your audio layer and position the start time of the copies to whatever interval you want. A bit of work, but certainly feasible.
Dan
