Is there a expression which can : value + previous value
COW Forums : Adobe After Effects Expressions
Krista van der Wilk
on Feb 3, 2012 at 5:17:08 pm
hello !
i made a NUll object with : Converting audio to keyframes.
With this data i would like to time remap a animation.
When i link time remap to the slider
The animation will go forward and back on the beat.
Converted audio slider: linear(value,0,100,0,10)+time
Animation layer time remap: thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider")
But i want it to go forward at the pace of the music but NOT backward.
So i am looking for a expression which can count the current and the previous value together ..
Hope this makes sense and someone can help me.
Greetings Krista !!
No knowledge is a Statement
Paul Roper
Re: Is there a expression which can : value + previous value
on Feb 3, 2012 at 6:01:04 pm
Having variables accumulate over time in After Effects is a real pain, but Dan's your man for this kinda thing; this will hopefully help you a lot:
http://www.motionscript.com/design-guide/audio-count.html
- Paul
Paul Roper
on Feb 3, 2012 at 6:07:23 pm
...If you want to use Dan's expression to control a 2-dimensional array (eg. 2D position), just change the last line ( n ) to this, where the *20 is to amplify the amount of movement - change it to suit your needs.
[n*20,value[1]]
Immanuel Morales
on Feb 12, 2012 at 4:39:13 pm
try using .valueAtTime([time]-[seconds]) and .frameDuration*[number of frames].
var prev = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider").valueAtTime(time-thisComp.frameDuration*2);
Krista van der Wilk
on Feb 14, 2012 at 10:12:43 am
i cannot check it right now, but this sounds as a reasonable solution !!
