Ref Audio Amplitude from parent comp from inside nested comps
COW Forums : Adobe After Effects Expressions
Brian Mills
on Jan 26, 2012 at 7:24:45 pm
Hello all
I have a project where i have an expression that uses audio amplitude to turn on lips during whistling. I have many different scenes I am setting up that are going to be there own comps.
I want to use these comps on a main comp with the music reference. So that way if I move these nested comps around and the timing with the music will still trigger the lips to turn on to make it look like h=they are whistling with the song.
Can i reference an audio amplitude layer on the main comp from inside the nested comps?
Brian
a = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
if (a >.3) 100 else 0
Dan Ebberts
Re: Ref Audio Amplitude from parent comp from inside nested comps
on Jan 26, 2012 at 7:34:00 pm
Sure:
a = comp("Main Comp").layer("Audio Amplitude").effect("Both Channels")("Slider");
Dan
Brian Mills
on Jan 26, 2012 at 9:05:29 pm
Thanks again Dan!
