ValueAtTime on Scale property
COW Forums : Adobe After Effects Expressions
Jamil Yamani
on Jan 21, 2012 at 11:18:16 am
HI all
I have been using Dan Ebberts code modified for Colour and various other things with great success.
I have tried applying it to a Scale property and it did not work. The scale value once the expression is turned on remains at 100%, 100% despite the keyframes I have applied.
Thanks in advance
Jamil
delay = 6;
d = delay*thisComp.frameDuration*(index - 1);
thisComp.layer(1).transform.scale.valueAtTime(time - d)
The Electric Canvas
Large Format Projection Specialists
Sydney, Australia
ben g unguren
Re: ValueAtTime on Scale property
on Jan 21, 2012 at 3:18:24 pm
Scale is multi-dimensional, so you need to produce 2 or 3 numbers (3 if the 3D switch is enabled) instead of 1.
It's easy enough to do; just assign a variable to the last line:
a = thisComp.layer(1).transform.scale.valueAtTime(time - d)
Then make your answer apply to X and Y with the following:
[a,a]
Or, if it's 3D:
[a,a,a]
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
Dan Ebberts
on Jan 21, 2012 at 4:39:41 pm
Your expression should work fine. My guess is that maybe layer 1 is not the one with the keyframes.
Dan
Jamil Yamani
on Jan 21, 2012 at 6:31:25 pm
you are very right, its all working now.
thanks very much to all of you
jamil
The Electric Canvas
Sydney, Australia
