If Else Easy Ease
COW Forums : Adobe After Effects Expressions
Barry Suydam
If Else Easy Ease
on Jan 20, 2012 at 3:50:06 pm
Was wondering if it was possable to add an ease in to this expression below?
if (transform.xRotation > 90) {
0
} else {
value };
Dan Ebberts
Re: If Else Easy Ease
on Jan 20, 2012 at 5:44:06 pm
What are you easing from and to, and over what range? You could do something like this, but I doubt it's what you're after:
r = transform.xRotation;
ease(r,80,90,value,0)
Dan
Barry Suydam
on Jan 20, 2012 at 6:21:10 pm
thank you for responding i really appreciate your help.
I have layers revealing like a flap using one of your inertial bounce expressions. I keep them at 0 opacity until they reach 90 degrees at which time the become 100 opacity and the bounce(flap) and rest at 0 degrees based on a decay parameter. They go from off to on I was hoping they could ease from 0 opacity to 100 opacity over 5 frames or so...so they didn't just pop on screen and continue to be 100 for the remaining duration of the layer in the timeline
Dan Ebberts
on Jan 20, 2012 at 7:12:56 pm
Is there a rotation keyframe at 90 degrees? You need something to trigger the ease expression, otherwise you have to create a loop that goes back in time to find the transition to 90 degrees?
Dan
Barry Suydam
on Jan 20, 2012 at 7:58:09 pm
x rotation is keyframed starting at 180 over 30 frames it goes to 0 with the following expression tied to it:
amp = .3;
freq = 1.0;
decay = 2.0;
n = 0;
if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time){
n--;
if (n == 0){ t = 0;
}else{
t = time - key(n).time;
if (n > 0){
v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{value}
Opacity has the following expression tied to it:
0
} else {
value };
I sincerely thank you for taking the time to work with me on this.
Dan Ebberts
on Jan 20, 2012 at 8:18:22 pm
Assuming the x rotation reaches 90 degrees half way between the first two keyframes, this should work:
fadeFrames = 5;
rX = transform.xRotation;
t = (rX.key(1).time + rX.key(2).time)/2;
if (time >= t)
ease(time,t,t+framesToTime(fadeFrames),0,100)
else
0
Dan
Barry Suydam
on Jan 20, 2012 at 8:38:37 pm
Perfection! Thank you...so much! Works perfect just changed the keyframes to 3. AWESOME!
Scott Green
on May 9, 2012 at 3:40:48 pm
Hi, I'm just reading up about expressions and learning the basics and came across this post while searching for a way to ease a rotation effect I've got attached to a null that controls a camera.
This expression affects the rotation which stops at 180 degress:
t=time*5 +10;
if(t<180){[t];
}else{[180];
How can I ease this effect so that the camera doesn't stop so sudden?
Thanks.
Creative Multimedia Design Manchester | S©tt Green | Splurj
Dan Ebberts
on May 9, 2012 at 4:31:54 pm
One way:
easeOut(time,0,34,10,180)
Dan
Scott Green
on May 9, 2012 at 6:11:35 pm
Thanks Dan,
can you tell me what each of the numbers represent please, I haven't got that far yet :)
(time,0,34,10,180)
Dan Ebberts
on May 9, 2012 at 6:18:52 pm
The expression just says "as time varies from zero to 34 seconds, vary the output from 10 to 180 degrees". I chose 34 seconds because that's the time it takes your original expression to get to 180.
Dan
Adrien Girault
on Jul 26, 2015 at 7:21:27 am
Hi, I was wandering if someone could help with the 'ease' in this expression:
I have footage which I've linked to the 'sound key' values so as to automatically speed up and revert back at a certain value.
but I'd like to add an ease expression to smooth the transition between both states.
The max value is 20.
I've tried a few different thing but no luck.
Any input would be greatly appreciated.
>x = time*2;
y = value;
if ( thisComp.layer("Adjustment Layer 2").effect("Sound Keys")("Output 1") > 10) {value = x} else {value =y};
ease(t, value1, value2)
