Write or Change Expressions for many layers at the same time. Is this not possible?
COW Forums : Adobe After Effects Expressions
leif falk
on Jan 12, 2012 at 4:59:39 pm
Hi Community
I ask myself and you why when I select multiple layers and then for example press "s" for scale and select all "scales" again and then I press alt + click the stopwatch and write some expression, only one layer gets the expression. The other layers only get a standard expression "transform.scale".
What if I have 50 layers for example and want to change a expression for all of them, do I have to copy and paste the expression 50 times? Is there no way to change all of them at once?
Thanks for replies.
P.S.
I tested with AE_CS5
Dan Ebberts
Re: Write or Change Expressions for many layers at the same time. Is this not possible?
on Jan 12, 2012 at 5:27:28 pm
After you edit the expression, make sure the property is selected, Edit>Copy Expression Only, select all the other layers, Edit>Paste.
Dan
leif falk
on Jan 12, 2012 at 5:44:56 pm
Thats it, I thank you so much, you saved me a lot of hours I guess..
