Manipulating an expression's timing
COW Forums : Adobe After Effects Expressions
Richard Noble
on Dec 16, 2011 at 3:01:12 pm
Hello,
I'm fairly new to expressions and have a problem I'm pretty certain there is a simple solution for.
I'm using Dan Edbert's pendulum expression which works amazingly -
http://www.motionscript.com/expressions-lab-ae65/pendulum.html
I am applying the expression to the z axis of a piece of footage to simulate a swinging from a wire effect.
The expression starts at frame 0 by default, but I would like to be able to dictate when the expression starts and stops. For example if I want to start the expression at frame 300 and again at 350 in the same piece of footage, what control setup do I need?
I'm pretty sure I can use a slider control, but I'm stuck at how to construct the correct controls.
If someone has a simple solution I would be very grateful
Richie
veloc = 7;
amplitude = 80;
decay = .7;
amplitude*Math.sin(veloc*time)/Math.exp(decay*time)
Kevin Camp
Re: Manipulating an expression's timing
on Dec 16, 2011 at 4:37:41 pm
something like this would allow you to use layer markers to control the timing for the start of the 'wobble'.
veloc = 7;
amplitude = 80;
decay = .7;
n = 0;
if (marker.numKeys > 0)
n = marker.nearestKey(time).index;
if (marker.key(n).time > time) n--;
if (n > 0)
t = time - marker.key(n).time;
else
t = 0;
amplitude*Math.sin(veloc*t)/Math.exp(decay*t)
to control how long it wobbles, you'd need to adjust the veloc, amplitude and/or decay variables.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Dan Ebberts
on Dec 16, 2011 at 4:49:41 pm
Here's the same thing with a couple of syntax issues resolved:
veloc = 7;
amplitude = 80;
decay = .7;
n = 0;
if (marker.numKeys > 0){
if (n > 0)
else t = 0;
Dan
Kevin Camp
on Dec 16, 2011 at 6:03:11 pm
thanks dan.... sorry richard if there was any confusion.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
