Null + variance
COW Forums : Adobe After Effects Expressions
David Hildreth
Null + variance
on Oct 14, 2011 at 9:10:55 pm
I have many elements attached to one null with a change in position.
I'd like to have all the elements to generally maintain the same movement, but with some degree of variance between them. Is there a way to easily add 10 or 20px of random difference between the position change in each element? I'm not exactly sure where to start.
Dan Ebberts
Re: Null + variance
on Oct 14, 2011 at 9:44:04 pm
Do you just want a random offset? If so, either of these should work:
maxOffset = 20;
seedRandom(index,true);
value + random([-maxOffset,-maxOffset],[maxOffset,maxOffset])
or,
wiggle(0,20)
Dan
