Repel/Attracting layers and random generator
COW Forums : Adobe After Effects Expressions
Dmitri Novikov
on Sep 29, 2011 at 11:32:37 am
Hello!
I'm newb at expressions so I killed a lot of time tryin to achive 'repel' effect. Then I found Colin Braley article http://www.colinbraley.com/repel_expressions_tutorial.html
I've tried to use Repel (Attracting) Expression (basic version) in 3D and it's still working. Awesome!
avoidPos = thisComp.layer("Attracted Layer").position;
maxDisplacement = thisComp.layer("Controls").effect("max disp")("Slider"); //maximum amount to move the layer
minDistance = thisComp.layer("Controls").effect("min distance")("Slider"); //minimum distance to begin displacing at
vec = avoidPos - position;
directionVec = normalize( vec );
distance = length( vec );
displaceAmt = ease( distance , 0 , minDistance , 0, maxDisplacement );
displacementVec = displaceAmt * directionVec;
position + displacementVec;
Exactly what I need.
But can anyone help me with combining this expression with another (Andrew Kramer's generator of random positions for the layers):
X=wiggle(0,thisComp.layer("RandomControl").effect("X")("Slider"))[0];
Y=wiggle(0,thisComp.layer("RandomControl").effect("Y")("Slider"))[1];
Z=wiggle(0,thisComp.layer("RandomControl").effect("X")("Slider"))[2];
[X,Y,Z]
So I can generate random positions for the multiple copies of the layers but they still will be respond to the movement of Attracting Layer.
One of the expressions just don't work if another pasted below.
Probaly I must edit this line "position + displacementVec" and add this random positions values to this. But I don't know how.
English is not my native language so I hope someone will understand this.
I will be very grateful for help.
Kevin Camp
Re: Repel/Attracting layers and random generator
on Sep 29, 2011 at 4:49:22 pm
i think you just need to use your random positioning statement as the 'position' in the repelling statements...
vec = avoidPos - [X,Y,Z];
if that still gives you problems, you could do the random positioning expression first, then convert that expression to keyframes, then apply the second expression. if you choose copy expression only for a selected layer, you can then paste it onto a all selected layers, so it would be pretty easy too.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Dmitri Novikov
on Oct 17, 2011 at 9:11:07 pm
"...you could do the random positioning expression first, then convert that expression to keyframes, then apply the second expression..."
I forget about this. Thank you. Really helpful
