following position x
COW Forums : Adobe After Effects Expressions
Josh Holdens
on Sep 18, 2011 at 1:25:01 am
Alright here's what I'm trying to accomplish. I want to be able to follow a given property(in this case position), but specifically the x or y position. I thought it would be as easy as setting a variable then adding the valueAtTime expression, but I'm definitely missing something.... I saw the delay expression but I'm still unsure how to apply that in this case.
x = thisComp.layer("White Solid 2").transform.position[0].valueAtTime(time - 1);
y = value[1];
[x,y]
Dan Ebberts
Re: following position x
on Sep 18, 2011 at 2:58:16 am
You just have the array indexing for x in the wrong place. Try it this way:
x = thisComp.layer("White Solid 2").transform.position.valueAtTime(time - 1)[0];
y = value[1];
[x,y]
Dan
Josh Holdens
on Sep 19, 2011 at 11:29:49 am
Great big thanks, I was completely stomped.
