Scale change loop
COW Forums : Adobe After Effects Expressions
Joel Gamble
Scale change loop
on Sep 5, 2011 at 1:48:48 am
I am trying to figure out an expression that will scale an object from 105% to 95%, and then from 95% to 105%, continuously through the animation. Each scale (e.g. 95% to 105%) would last 1 second.
I can't figure out how to loop the effect. I know how to do this in Java (using if statements, but the syntax isn't the same in javascript. Below are the lines I have figured (not much, I know...)
Any help would be greatly appreciated!
Thanks in advance,
JG
linear(time, 0, 1, [105,105], [95,95]);
linear(time, 0, 1, [95,95], [105,105]);
Dan Ebberts
Re: Scale change loop
on Sep 5, 2011 at 3:44:33 am
This should work:
t = (time-inPoint)%2;
if (t < 1)
linear(t, 0, 1, [105,105], [95,95])
else
linear(t, 1, 2, [95,95], [105,105]);
Dan
